Amp Help - FirebirdV6.com/CamaroV6.com Message Board
Amp Help
  • Amp Help
    Im thinking of getting two 12''kicker s7's and i wanted to know what you think about amps. I want to get as close to the rms (i think 750w) as i can. i am thinking of getting (2) one channel amps, or, (1) two channel amp, or (1) one channel amp. if i get two amps, i would hook one to each sub. the two channel, one to each channel. and i went to circuit city and the have 2 subs hooked up to a one channel amp, and it sounded pretty good, i just dont know how to do that. So, keeping in mind that i want as close to 750 to each sub, what amp should i get. also, i want to keep the price of the amp(s) under 400 or 500.
    thanks
    Re: Amp Help
    I'm assuming you mean L7s, not S7s. I'd say get 2 4ohm models (06S12L74) and run them both off (1) one-channel amp. Find an amp that can do 1500WRMS @ 1ohm and you're set. But trust me, those subs will get hella loud in an F-body. I have 2 12" L5s (the L7's little brother) and they pound like no other. But if you are set on 2 12" L7s, get the 1500WRMS one-channel amp.
    http://ikesound.com/product-product_id/4369
    That amp will work.
    <b><i>Don\'t Ever Judge Me</i></b><br /><a href=\"http://www.cardomain.com/id/earnhardt132000\" target=\"_blank\">\'96 Firebird Y87 3.8L V6 5spd</a><br />--No mods as of yet, shoot me some ideas if ya want.<br />178,000 miles and counting
      Re: Amp Help
      On wiring both your subs to a single channel:
      http://mobile.jlaudio.com/support_pages.php?page_id=161
      Buy dual 4 ohm subs and this amp:
      http://cgi.ebay.com/HIFONICS-BXi1606...em140085883445
      Topic closed. LOL!
      EDIT: Hey! Same time post! How come I'm on the bottom? And BTW, I had two 15" L7's powered off 3kWRMS. I know I was over 150db.:excited:
      Red 96' A4 Firebird
      Audio Audio and Autotek
      Check it out here!
        Re: Amp Help
        I'm just too quick :).
        And I edited my post with the same amp you posted, this is kinda weird...
          Re: Amp Help
          Well, that amp does seem great, but it says the rms is 1100 and 1600, would that ruin my subs at all, or be too much power? Also, i was thinking of getting a kicker amp, do you recomend the hifonics over kicker?
          Thanks for the help.
            Re: Amp Help
            Kicker is WAY expensive. You'd be looking at $300+ just to power one of the L7s. Don't get me wrong, they are awesome amps. But a budget amp will do just as well for a lot less.
            And that amp does 1100WRMS @ 2ohm, you can ignore that because you would be running @ 1ohm with 2 dual 4ohm subs. And 1600WRMS is only 100 watts above the recommended 1500WRMS (750*2=1500), so as long as you tune the amp correctly and don't crank it all the way all the time you should be fine.
              Re: Amp Help
              ohhhh, i thought you were telling me to get two of those amps, one for each sub. haha. yea, that makes sense now. so i just have to connect the two L7's (thank you for correcting me before, i forgot to mention, haha) to the hifonics amp.
              Thanks, you just made my life so much easier.
                Re: Amp Help
                Yup, like this...
                http://mobile.jlaudio.com/graphics/S...Parallel_2.gif
                  Re: Amp Help
                  Originally posted by Earnhardt132000
                  why are there two pos and negs on each sub?
                    Re: Amp Help
                    Its a dual voice coil subwoofer. All the L7s are like that...... and most subwoofers now-a-days. Performance wise, it makes no difference to have single or dual voice coils. Just gives you more flexability when matching up an amp.
                    Example.... you don't HAVE to follow along.... just trust me. lol:
                    If the L7's were single voice coil 4 ohm. Your choices would be 2 and 8 ohm final load on the amp.
                    The L7's were dual voice coil 4 ohm. Your choices are 1, 4 and 16 ohms final load on the amp. One extra choice.
                    Red 96' A4 Firebird
                    Check it out here!
                      Re: Amp Help
                      ooo, i kinda get it. i can never follow all these specs on subs and amps, its all so confusing. im pretty sure ill figure it out though.
                        Re: Amp Help
                        Check out www.bcae1.com to learn a lot about car audio and electronics in general.
                          Re: Amp Help
                          haha, wow, thanks, i was actually going to ask someone if thet had a site like this. this is going right in my bookmarks. thanks a lot.
