Is there a hole or something that I can use to get my foglight wires through the firewall so I can put the switch on the interior? I've tried to search, but didn't have any luck.
Wires through firewall
Re: Wires through firewall
You CAN put a hole in the firewall or you can remove your pcm and run throught there ............. here's that info.................http://forum.camarov6.com/showthread...=manual+switch
I like dan's idea
(and if you cant find the hole, remember to put fur around the hole, it helps finding the hole)
but seriously, you can always run the wires all ghetto style through where the top of the door meets, and goes under the hood (it fits great)
If you dont know what I'm talking about I will take a picture
But using this ghetto method for 5 years and have never cut a wire from slamming the door2k2 camaro, K&N, SLP whisper lid, Konis, AEM, HP Tuners, Angel eyes/Halos, CF SS ram air hood, 4.10s, Zexel Torsen, UMI SFCs, CrossFire, BFGs, Gatorback, Catco, Flows, and TLC! DONT feed the Trolls!
But using this ghetto method for 5 years and have never cut a wire from slamming the doorRed 1998 Camaro<br />Mods so far=<br />K&N
I hate that method...looks cheap to me. Make a hole on the drivers side or run them to the PCM area.
'66 Ford SOLD
Uhh..make sure nothings on the other side? lol i dont know
'66 Ford SOLD
id also be interested in learning how to do this a professional way. wanted to wire my halos to a seperate toggle switch so i could turn them on without my car being on, but could never find a good guide for getting the wires through the firewall. kudos to anyone that helps!1999 v6 Camaro M5
Automatic to Manual converted
Pacesetter Headers, 2.5" Custom True Duals with X-Pipe and Magnaflow Bullet Muffers,
!cat, Intake, 3.42's with LSD, MSD Wires, Drilled/Slotted Rotors, Hurst Short Shifter, Tuned PCM
Originally posted by Stock98camaroIs there a hole or something that I can use to get my foglight wires through the firewall so I can put the switch on the interior? I've tried to search, but didn't have any luck.
Remove the screw above the wire bundle coming through the firewall on the drivers side. That's where I am running my fog light switch wire.
http://www.geocities.com/MotorCity/T...foglights.htmlRobert - owner www.FirebirdV6.com/CamaroV6.com
Raven
