hugh problem - FirebirdV6.com/CamaroV6.com Message Board
hugh problem
  • hugh problem
    Ok first problem: when I turn on my turn signal (either left or right) the light stay on and doesnt blink.
    Second problem: Every time I try to crank up my car it doesnt turn on and I have to undo the battery wires weight 30 seconds and then connect them to crank up the car. Now when I do that my car doesnt do anything.
    do you all thing the 2 problems go hand in hand meaning there might be a shortage? but where i didnt start having this problem until I moved to maryland from texas.
    Re: hugh problem
    The blinker, not blinking is a bulb out..
    its sort of a " bulb out indicator ".. go over your car and check the bulbs, replace them if they are out.
    if all the bulbs are out, replace the flasher.
    it is located under the steering wheel, there are write ups on it.
    the flasher is pretty cheap!
    *Matt
      Re: hugh problem
      what he said, and you might have a bad starter too
        Re: hugh problem
        I think your problem is you shouldnt have moved
          Re: hugh problem
          It's the flux capaciter. That or change the blinker fluid.
          \'99 3.8 Firebird<br />Red, T-Tops, Chrome Dante 17\'s, Cold Air Intake, Free Ram Air, K&N Filter, Flowmaster Duels, Performance Plugs/Wires, CATless, Smoothed out Lid<br /><br />Young girls avert their eyes, weak men tremble, Ford dealers faint...<i>Firebird Power!!</i>
