What kind of resistor should I get? - FirebirdV6.com/CamaroV6.com Message Board
  • What kind of resistor should I get?
    Hello, I seem to have the famous "VATS" problem everyone seems to have. I have read numerous posts from many many members and have finally found two solutions:
    1) Go to a dealership and get it fixed. However, I'm a broke college student and am unable to pay $200-$300 to get it fixed.
    2) Bypass the security system by buying a resistor from Radioshack for like a couple of bucks and then installing it.
    My question is, since I am going to be doing choice #2, I need to get the OHM reading from the sensor on the key. I am just wondering, for anyone who has done this or anyone that might know, what kind of resistor do I need from Radioshack? Is the ohm reading different on every car or is there one for all cars? And if there is a different reading for them all, how can I get one? Anyone knows where I can find an OHM meter?
    <a href=\"http://www.cardomain.com/id/1995birdman\" target=\"_blank\">http://www.cardomain.com/id/1995birdman</a>
    Re: What kind of resistor should I get?
    Go to Radio Shack have some one there ohm out or check the chip on your key. Get a 1/4 watt ressitor of that size and you will have what you need.
    2000 Firebird A4, 3.42 LSD, K&N, Free Cold Air, PaceSetter, 3" in/out Catco, 3" S-Pipe, 3" Intermidiate Pipe, 2.5" Flowmaster 80
      gman has got it covered.
      But if you want to keep the vatts, it might be that the resistor in you key is bad. Aftermarket keys normally don't last as long as the factory ones. My system was acting up, i went to a locksmith and had them make me a key out of a GM key, and it's worked just dandy.
      1996 Chevrolet Camaro
      1995 Buick Park Avenue Ultra
      --Appearance Moderator--
        So what you are saying is I should get the resistor AND go to a locksmith and get a copy of the GM key but without the resistor in the key? Or just go a locksmith and get them to make me a copy of the GM key? 'cause i thought only dealership did the GM keys?
          If you're looking to replace or copy your car's ignition key, you'll need to know what VATS chip you have in your current key. Grab any meter that measures resistance. Touch a probe to each of the metal leads going across the VATS chip in your key. Use the chart below:
          GM Key Number----Value (Ohms)
          1------------------392
          2------------------523
          3------------------681
          4------------------887
          5------------------1130
          6------------------1470
          7------------------1870
          8------------------2370
          9------------------3010
          10-----------------3740
          11-----------------4750
          12-----------------6040
          13-----------------7500
          14-----------------9530
          15-----------------11800
          http://cgi.ebay.com/ebaymotors/CHEVY...92185328QQrdZ1
          Booya.
          Red 96' A4 Firebird
          Audio Audio and Autotek
          Check it out here!
            Thanks bro, I bought the potentiometer yesterday and installed it today, it was easier than i thought and the only thing that took the longest was connecting the wires to the potentiometer's ends w/electrical tape. The car has started up fine with the "sensor-less" key which was copied from my original GM key. I'm very happy and I encourage anyone having this problem to go ahead and fix it this way.
              Renzo... were in the wiring do you place the resistor?
              Lounge Moderator
                Bonemaro, look at the link down below, its those tiny white wires right after the VATS connector, which are then followed by the orange covering you see there. You have to unplug the VATS connector and then take the connector along with the white wires and cut right before getting to the orange covering. Once you have the connector in hand, just connect it to your resistor and plug it back in and VOILA! Here is a guy that did it and wrote a thread for it:
                http://web.camaross.com/forums/showt...ypass+security
                And here is the diagram of the wiring:
                http://shbox.com/1/air_bag_disc_2.jpg
                Let me know if you need more help.
                  FYI our keys are a number 11 blank.
                  1995 Patriot Red T-Topped Z28 A4<br /><br />Mystery rebuild in progress.<br /><br />Soon to have 383 ways to beat KBreezy and Shane. :D
                    I have my resistors all ready and have the panel off and found the wires. Next question is which of the two wires do I put the resistors on?
                    Also, do I need to have a new key made that does NOT have the resistor on the key?
                    Red 1998 Camaro<br />Mods so far=<br />K&N
                      From the picture above....
                      You need to cut that "orange" wire after the orange and before the VATS connector.
                      After you have the 2 different wires, connect the resistor to both ends of the wires with crimps or good 'ol solder.
                      Then tape em up.
                        Then tape em up.
                        So I put my resistors in BOTH wires? I need a resistance of 3k OHMs. I have 3 1K OHMs soddered together. So would I get my 3 resistors and put them in one of the two wires, and then get another 3 resistors and put it in the other wire? That would make a total of 6 resistors and 6k Ohms though, unless I am not understanding something.
                        Sorry for all the difficulty, but I feel like I am just one step from the finish line with this project! :) Thanks for everyones help so far!
