Turn signal light - FirebirdV6.com/CamaroV6.com Message Board
Turn signal light
  • Turn signal light
    Ok here's the thing thats happening from today morning ..........put my indicator to left, it works fine (blinks ) but when i put my indicator to right, it stays on solid (without blinking) .........what's going on? .......do i need new bulb?
    09 Nissan 370Z MB M6 Sports Package
    www.the370z.com
    Re: Turn signal light
    get into the rt turn sigs and see if the bulbs burned out.
    if the bulbs are good or u replace them and same, look in fuse box for flasher unit.
      Most likely it's the bulbs, because he said the left ones work just fine. Anyway, the flasher unit is behind the panel that is on the driver side just under the steering wheel, not in the fuse box.
      1996 Chevrolet Camaro
      1995 Buick Park Avenue Ultra
      --Appearance Moderator--
        It should not be the flasher. Check or replace the bulbs (front and rear). Also, it could possibly be a bad ground. If it lights up as you say it does, I would suspect a bad bulb.
          Did you post this question to just to add to your post count or are you serious?
          one bulb circuit is out. replace your bulb and inspect the socket
          2000 3.8 A4 Pewter Camaro
            Umm no ........i really don't care about my post count .......i am not "vanbibber" :rolleyes: .......
            ok, i am lazy ....... i just woke up ..........i am going to get suited up and check it out right now ......
            www.the370z.com
              It is your bulb...turn on your hazards and take a look around at your 4 blinkers and find the one that isnt blinking. By they way...replacing them is a pain in the ***...atleast for the '98-'02.
                Da*n it ........it's the front right signal ........ it's freezing cold and the fronts are pain in the a$$ anyway...........oh well, i guess i'd have to wait till spring time ............ :) .........thanks for the info guys
                www.the370z.com
