im lookin for HID headlights for my 97 camaro, but i cant find any website that makes them for the freakin car... i was told xenonking.com or somethin like that... ne ideas?
hid headlights???!!!
Re: hid headlights???!!!
You dont need to buy an expensive conversion kit or any of that junk. All you need to do is buy 2 9005(low beams) and 2 9006(high beams) bulbs and simply take your old headlights out and remove the bulb from them. I have a 97 camaro and I did this and they work great, and it cost about $25 to get everything here.
I cant find the website that had the write up on it but all you do is take the old headlight and cut around the base of the buld with an exacto knife or something like that to cut the glue holding the bulb in and then remove the old bulb, take the new bulb and put silicone around the base(in the groove that will be touching) and put the new bulb in and then make sure its straight in there and let dry for a day just to be safe. Its not hard to do at all and its cheap too.
yeah, HIDs..Originally posted by camaroz87hes talking about HID headlights not regular bulbs
Keep searching eBay, i've seen a few conversion kits on there at times, though most the time there is nothing. What you can do though, is buy your desired headlight with the bulb you choose (eg H4) and then buy an H4 HID conversion kit. You can then swap that and the HIDs you want.
