Power locks switch - FirebirdV6.com/CamaroV6.com Message Board
Power locks switch
  • Power locks switch
    how hard involved is it to replace/repair?
    Re: Power locks switch
    Just to take the switch out and put a new one in? Pretty easy really. Remove the 2 screws holding the plastic bezel (that surrounds the door handle) onto the door panel. Unlock the doors so you can remove the lock slider plastic. Then lock the door back so the lock rod is out of the way. Remove the plastic bezel from the door panel, unhook the wires from the switches. Once the bezel and switch plate assembly is free from the door, push the switch plate out of the bezel from the inside outward. Then you can stick 1 small flat screw driver in each side of the switch mount clips on the switch plate from the back. Then push the switched out from the outside inward. Reverse the process with new switches installed, and you're doine.
    I hope all that made sense. It'll be alot easier when you start taking stuff apart to look.
    Byt the way, I've got a couple switches for sale http://forum.camarov6.com/showthread.php?t=78195 if you need. I dunno exactly what vehicle you're working on, but if I can help, lemme know.
    ~Chris<br />1999 Hugger Orange Camaro<br /> <a href=\"http://www.cardomain.com/ride/273836\" target=\"_blank\">http://www.cardomain.com/ride/273836</a> <br /><br />†…faith…hope
      Thanks!
      I have a 95 camaro, will that switch fit?
        Originally posted by bluttop
        Thanks!
        Yeah, it should. It's out of a 94 Camaro. Do you need the window switch too, or just the lock switch? Also, are you after the driver side window switch (has two switches), or the passenger side single switch. Lemme know.... post up over there.
          5 days ago
