ok so i just noticed that my odometer is not lighting up anymore. the only time i can see it is after dark with the headlights on. is there any way i can fix this myself, or do i hae to replace the cluster?
odometer
Re: odometer
Assuming you have already tried adjusting your lighting with your switch, that switch might be bad
Re: odometer
ok today i took the insturment cluster apart and found that there is a light bulb directly behind the odometer. i think that light bulb is burned out. when i put a flashlight behind the odometer, the numbers were illuminated like they should be. so, i may be wrong, but i think that the lcd lights up a certain amount, and that is what i can see after dark, but the light bulb behind it is burned out, so thats why i cant see it in the sunlight. so my question is how hard would it be to desolder the bulb and replace it? also, where could i get the bulb from?
by DongrossmdI’m new. I actually don’t own a Camaro or firebird. I do have a 2000 Camaro 3.8 fly by throttle and 4l60e. This is installed in a 1980 Triumph TR7...7 hours ago
