door windows - FirebirdV6.com/CamaroV6.com Message Board
door windows
  • door windows
    I got this weird problem.Every once in a while my driver's side window will stop rolling up,if I gun the car I can get it to move up alittle.I have to do this several times to get it to go up all the way.Today it stopped all together and I had to turn the car off for awhile and it went up after that.Does anyone know what might be causing this?
    Re: door windows
    Bad window motor. Mine did the same thing when it was just about burned-out.
    Oh, and stop gunning the car, it isn't helping the situation :)
      Re: door windows
      mine too. the way i work it is when i need to open window, I push down on glass and push the switch and opposite to close it. it works but i still need to change it
        Re: door windows
        my car is currently in getting the passenger window motor replaced, sucks but has to be done
        2000 Camaro 3800 A4
          Re: door windows
          ...and soon, it'll be the driver's side :rolleyes:
            Re: door windows
            takes like 20 minutes tops per side. I have taken longer than 20 mins to change some car's oil
            remove door panel, drill holes to get to rivets, remove rivets, bolt on new motor, reassemble
            2000 3.8 A4 Pewter Camaro
              Re: door windows
              do you need to put new rivets in or would screws or something else work?
                Re: door windows
                And this is why I now enjoy my manual windows
                <a href=\"http://www.cardomain.com/id/1995birdman\" target=\"_blank\">http://www.cardomain.com/id/1995birdman</a>
                  Re: door windows
                  the motor should come with new small bolts and nuts
                    Re: door windows
                    my drivers side motor's runnin like a champ... but my passenger window basically stopped working, so lets just hope it doesnt come down to replacing the drivers side...
                    2000 Camaro 3800 A4
                      Re: door windows
                      is it possible to convert power windows to manual ones?
                        Re: door windows
                        try this too: http://www.autotrix.net/
                        Check out my cardomain site!<br /><a href=\"http://members.cardomain.com/99pewterv6\" target=\"_blank\">My Car</a>
                          Re: door windows
                          try this too: http://forum.camarov6.com/showthread.php?t=40529
                          Red 96' A4 Firebird
                          Audio Audio and Autotek
                          Check it out here!
