okay guys we have a stock alarm on an 01 camaro and when you set the alarm it beeps like normal but then the alarm activates about 7-8 seconds later for 2 honks then stops (like you hit the panic button for 2 honks) i thought maybe it was the keyfob battery no i reset the keyfob no luck there so i manually locked the doors from the inside shut the doors walked away and it freaking did it again!!!! help
stock Alarm problems.. Please help!!!
Re: stock Alarm problems.. Please help!!!
Originally posted by vr4gasmokay guys we have a stock alarm on an 01 camaro and when you set the alarm it beeps like normal but then the alarm activates about 7-8 seconds later for 2 honks then stops (like you hit the panic button for 2 honks) i thought maybe it was the keyfob battery no i reset the keyfob no luck there so i manually locked the doors from the inside shut the doors walked away and it freaking did it again!!!! help
thats fine i already woke the neighbors up haha um.. i know other people have this problem i searched and people had the same problem but no one had an answer as to why or what started it2001 Camaro 3.8 A4
1991 3000GT VR4
2001 Mitsubishi Eclipse GS
I was changing alternator last month at 10am and forgot about the alarm going off when the battery is messed with before it totally disconnected. The horn honked twice that time as well. Then all hell broke loose and I was wrenchin like a mutha F&C*#@
2 honks is like a warning signal for a light impact to the car.. My car honks twice when the firetruck drives by.. well actually, the firemen know my car does, so they down shift in front of my house every time they drive by to make sure it goes off lol. I know this isn't your problem, but it might possibly have something to do with the shock sensor?
last night 3 times for NO reason the car went in to the 2 min. alarm mode!! grr i was looking at ls1tech and a guy was having the same problem somehow after a hard rain his shock sensor got filled up with water and was shorting out he drained it and dryed it.. it has been downpouring here for a few days and the other guy with the problem also said it happened after a hard rain.. so i am gonna take it apart later tonight and try my luck with that...2001 Camaro 3.8 A4
1991 3000GT VR4
1998 camaro does this too. it started doing it after i put my JL amp in and did it almost all the time, then i pulled it out in fall and it was fine. i think it might be the ground wire in the back of the car that needs to be cleaned, well thats waht im gonna try. cuz when i put my amp in the summer my car acted all funny , and it was because the chassi grounds were corroded, adn had a bad connection.
Originally posted by mazzon1998 camaro does this too. it started doing it after i put my JL amp in and did it almost all the time, then i pulled it out in fall and it was fine. i think it might be the ground wire in the back of the car that needs to be cleaned, well thats waht im gonna try. cuz when i put my amp in the summer my car acted all funny , and it was because the chassi grounds were corroded, adn had a bad connection.
