its inside the dash area im pretty sure, check ur repair manuel to find it but im sure its either in the steering column area or on the right side behind the glove compartment
please do not start screwing with your control module. just simply unplugging the module too many times will lock it up forever. I have seen it done by just unplugging it 3 times. Who knows if it did it prior to that. The technician was not happy and I learned a valuable tip. :)
