I fixed my axle, and now randomly, everytime I start my car, the security light will stay on, blink about 3-6 times and then go off once I start driving. or give it gas. I think this has something to do with a ground I messed with, am I right or just retarded??
Wth?!?!?!?
Re: Wth?!?!?!?
I doubt it has anything to do with what you did. Sounds more like a dirty key / lock cylinder. Clean the chip on your key with some rubbing alcohol, and blow out the ignition with some compressed air.Representin' Team Red In The North
Red '96 Pontiac Firebird "Smokeshow" 3800, M5, Far From Stock!!
Black/Red '89 Jeep Cherokee "Tigerclaw" Chev 327, Turbo 400... Stock What??
Black/Red '02 Honda CBR 954RR Fireblade
Re: Wth?!?!?!?
It could be a problem with ground, I messed with a ground connection under the hood of my car one time, and I had most of the warning lights on my dash flashing at me, staying on.
If you want, check the ground.. clean it up, get a fresh surface and remount it.
Hopefully that takes care of your problem...
As for what was said above me ^ You can also use a pencil eraser to clean the resistor chip on your key.*Matt
