Damnit..sub/amp problems - FirebirdV6.com/CamaroV6.com Message Board
  • Damnit..sub/amp problems
    So i bought a 250 RMS /500 peak rockford P2 10" from ebay
    I realized after i bought it that it was Dual 2 ohm voice coils.. (i wanted SVC)
    Therefore the sub runs at 250 RMS @ 4 ohms..
    I was hoping to get a mono black amp to run the sub, but most amps only push 150 RMS @ 4 ohms (the kicker amp i wanted anyways).. Would the kicker amp push the rockford P2 good? How do you wire a DVC into a mono block amp?
    If all else fails i have to get a 2 chan amp.. Im looking at 2 rockford amps right now, both are 2 chan and about same price.. here are their specs
    325 Watts RMS x 1 @ 4 ohms bridged (975 max wattage)
    400 watts RMS x 1 Bridged Output at 4 ohms (im assuming over 1k max wattage)
    Just to make sure.. do you plug each VC into 1 channel?
    I dont want to blow the sub or anything, so is there a way to check how much RMS the amp is running at?
    Re: Damnit..sub/amp problems
    For that sub, you can find a 1-channel amp that does 250WRMS @ 1ohm. That would probably be cheaper, but it needs to be 1ohm stable.
    <b><i>Don\'t Ever Judge Me</i></b><br /><a href=\"http://www.cardomain.com/id/earnhardt132000\" target=\"_blank\">\'96 Firebird Y87 3.8L V6 5spd</a><br />--No mods as of yet, shoot me some ideas if ya want.<br />178,000 miles and counting
