I have a 98 camaro and i assume that i have key less entry and the remotes got lost along the way. Ti has power locked windows and a alarm so i assume it has key less entry. Which remote do i get. I want one with the four bottons one for alarm. thanks for the help
Remote
Re: Remote
no they didn't all come with alarms. mine didn't come with a remote either, but it had keyless. Lock the car via the power lock switch, wait 30ish seconds, and knock on the passenger quarter panel. if it doesn't honk, you probabl don't have the system. Another way to check, open the door of hte locked car with the key, and in mine at least, if you don't get the key in the ignition and in the 'on' position within a few seconds, the alarm sounds.
Re: Remote
i have the alarm sensors and everything so mine does. I dont think they all did just do what he said and check if i lock my car with the power locks and open my trunk with the key my alarm automatically goes off98 Mystic Teal Camaro
Mods: FRA, K&N, Clears corners, runing lights, billet grille, All blue interior leds, All four highbeam mod, Halos
Re: Remote & alarm
does the factory alarm system have a flashing red LED in the dash vent?
I didn't get any remotes with mine. Not sure if it is a factory alarm or not. Haven't seen anything that looks like an added alarm but not sure where to look either.
I need to find a remote or two. Maybe I'll try to reprogram one of my z24 remotes. I rarely lock it up anyway but neighborhood kids have been known to steal cigarettes and roaches but at least they leave cds alone LOL. I should probably figure out whether it has an alarm before I get screwed over and stranded from a starter kill or something.
Re: Remote
Oh I do know it will honk, but no sirens or anything. I had set it off honking when I had the doors locked. I can shut it off with the ignition key. It seems stock from what I've encountered except the flashing LED.
Only have 1 ignition key too. That could be unsafe
