My subs shake the rear hatch and make a low buzzing noise when its one. Any ideas on how to stop the noise besides turning it down? Thanks for any suggestions
Subs shake hatch
Re: Subs shake hatch
Diner, matt...\'97 Camaro M5 Y87 3.23 LSD, homebrew CAI, highfloCat, Flowmaster catback, Pacesetter headers, specstage3 clutch and aluminum flywheel, !egr, 2kW system.<br /><br />Possible L67 bottom end w/ abbott heads and a turbo in the works... gotta do more homework
Never mind, I found it on other sites. Mainly this one http://www.sounddeadenershowdown.com/ . Dynamat is a lot better
I'm a huge fan of ED but their sound deadener is not up to par. Everything else is top notch though. If you want great sound deadener I suggest RAAMAT.2001 Arctic White Firebird With Black Drop Top<br /><br />3:42 Gears<br />Zexel LSD<br />BMR upper A-Arms<br />Trans Am exhaust with 3\" I-pipe and cutout<br />Modified intake<br />Mecham Hood<br />Trans Go shift kit<br />Making rear control arms and panhard
Originally posted by Chuck8_My subs shake the rear hatch and make a low buzzing noise when its one. Any ideas on how to stop the noise besides turning it down? Thanks for any suggestions
I put HOOD PINS in my hatch ( to stop 150db+ ) :dj: :dj:
you got to see the pics :D
http://www.cardomain.com/ride/2516564 :burn:
Originally posted by travis brackettI put HOOD PINS in my hatch ( to stop 150db+ ) :
Hood pins, please. :tdown:
my friends 94 camaro hit 155's all day long and he has no problems with his latch, nor would need or ever concider "hatch pins". :twak:
You whore your car an awful lot*Matt
Originally posted by travis brackettI put HOOD PINS in my hatch ( to stop 150db+ ) :dj: :dj:
http://www.cardomain.com/ride/2516564 :burn:2000 Camaro 3800 A4
Originally posted by StrtRacer98Overkill.
Hood pins, please.
I like to see pics your friends car.... :poke:
and its not overkill... I'm go for 160db... :slap:
3 new kinetik batts / 2 more monitors going in today
more over: hood pins $15 / dynamat $200+
if subs shake the rear hatch dynamat may fix noise but not the shake...
pins will fix the shake...
Note: dynamat test results on F150 had 9.1db less road noise and 6db more bass output (122 to 128db @ 45hz) material cost if $559 and a installation time of 11 hours
My car is a SQ car also I used Dynapad in the rear and Dynaliner on floors/doors
Originally posted by chuck8Any ideas on how to stop the noise besides turning it down? Thanks for any suggestions
