Yes, mine is gone. I am having trouble finding the attachment point near the power steering pump. A good description of where to look would help greatly.
<b>Cheers!</b><br />Scott<br />1994 Camaro 3.4L V6<br />Flows, Underdrive Pulley, and a 180 Thermo
It shouldn't make a difference where you attach the stap. All it is is a frame to block ground, so just find a boly you can access easily and attach it there.
Representin' Team Red In The North
Red '96 Pontiac Firebird "Smokeshow" 3800, M5, Far From Stock!!
