Yeah so maybe a week ago I noticed when I flick on my left turn signal it has a solid left arrow and it's quiet (no clicking sound)... anyone know what could be the problem?
I haven't actually went outside the car to see if it's working or not or what, but it's kind of annoying.
i have the same problem right now, it is the bulb in the front, im just too damn lazy to pull the headlight out and swap the bulb...its annoying as hell by the way. the back blinker dosnt even blink when the fronts out, it stays solid...
Today at work on my break I turned the left signal on and went outside the car, both the front AND rear lights were ON and they were solid... So the bulbs can't be out right?
So wtf is causing this? And how do I fix it?
Check the fuses and relay, all the parts are pretty cheap so just go down the line, I've never had them go out on my camaro but on my prevous car rear bulbs have double filaments and if one filment went they still lit up but didn't blink maybe someone could chime in whether that could still be the problem
