help? pleese? - FirebirdV6.com/CamaroV6.com Message Board
help? pleese?
  • help? pleese?
    i found this by my non-working cigerette lighter:
    what is it? what is it sapost to be pluged in to? and is it why my cigerette lighter dosent work?
    Tell me and i will let you do this to me: :spank:
    Re: help? pleese?
    Not to sound like an *** but if your cig lighter doesn't worka nd you found a plug not plugged in wouldn't that be logical. Here's a thought, plug it in and see if it works.
    Let's flip a coin. Heads I get tail, Tails I get head.
      Re: help? pleese?
      Well I want to do that but I don't know whare that plug goes and I was hopeing someone did
        Re: help? pleese?
        Pull your center console up and there should be a similar plug all alone looking for its buddy.
          Re: help? pleese?
          your right i feel bad now there probably both lonly and depresed, what have i done!!!
            Re: help? pleese?
            can anyone give me a hint as to whare to start looking for it's little buddy?
              Re: help? pleese?
              See if there is a way you can pull the cig lighter up from the top cause it will probably plug right into the back of it. If not you'll need to pull up the center console to access it. Good luck
                Re: help? pleese?
                Gonna have to pull the center concole out, but the wired thing is I already have 2 wires pluged into my brand new cigerette lighter, but it won't charge my phone, o well ill figure it out one day
                  Re: help? pleese?
                  Ok then, not sure of your year and the specific options available but on mine there is an aux 12v supply. Maybe it goes to that one. If not then pull the console and see what's alone.
                    Re: help? pleese?
                    It's a 95, I pulled up the piece with the ashtray, can't find any thing that goes to that, whares your 12 volt thing?
                      Re: help? pleese?
                      I got a 2000, the aux 12v is below the radio to the right of the center console
                        Re: help? pleese?
                        Mine might be someware neer there evin tho it's 5 years older, ill check, thanks for the help, and I like the hot dog thing
                          Re: help? pleese?
                          heres a new question, is there some gadget i can hook up to my battery that i can hook up to my cigerette lightter?
                            Re: help? pleese?
                            check your fuse buddy you have a fuse for the cigarette lighter in your fuse box and if its bad then nothing is gonna work phone or the cigarette lighter
                              Re: help? pleese?
                              ****s and giggles, I didn't think of that I feel dumb
