hey i was just wondering does this really work? thanks
Alternator Power Cable does really work
2000 camaro rs:whisperlid, 2.5 magnaflow exhaust, catco high flow cat, fast toys cai, 3.73, 160 power stat, msd 8.5 wires ngk iridium spark plugs, hpp3, zzp w/p and alt. under drive pullies, 1.9 Rockers/LS6 Springs with ls1 retainersTags: None
Re: Alternator Power Cable does really work
If you're talking about an alternator rewire with a larger diameter wire then yes. It works and is an inexpensive way to increase voltage across the board. It won't make much of a differance if you're not running a system or quite a few gadgets, but it is relatively inexpensive and has been tested to increase voltage.
Originally posted by Kal-Elhey i was just wondering does this really work? thanks
Yes. I have it. See my site for details for what you need.Robert - owner www.FirebirdV6.com/CamaroV6.com
Raven
so its just a 4AWG that goes from the alt to the batt?2000 camaro rs:whisperlid, 2.5 magnaflow exhaust, catco high flow cat, fast toys cai, 3.73, 160 power stat, msd 8.5 wires ngk iridium spark plugs, hpp3, zzp w/p and alt. under drive pullies, 1.9 Rockers/LS6 Springs with ls1 retainers
Originally posted by Kal-Elso its just a 4AWG that goes from the alt to the batt?
No, it is re-routed to the body power post. Look at the pictures on my site.
Alt to Batt 8awg (removed)
Batt to Power post 6awg (keep, now only used to charge battery)
Alt to Power post 4awg (new)
.Last edited by FirebirdGT; 08-08-2007, 05:02 PM.Robert - owner www.FirebirdV6.com/CamaroV6.com
Raven
ok let me get this straight so u take out the wire to alt to the batt then keep the the wire to the batt to power post then a new wire 4awg alt to the power post so there will be 2 wires going to the power post the new 4awg and the 6awg and by power post u me were all the fuse are right? i know zzp sales the wire stuff but does it come like the set up u have thanks2000 camaro rs:whisperlid, 2.5 magnaflow exhaust, catco high flow cat, fast toys cai, 3.73, 160 power stat, msd 8.5 wires ngk iridium spark plugs, hpp3, zzp w/p and alt. under drive pullies, 1.9 Rockers/LS6 Springs with ls1 retainers
Originally posted by Kal-Elok let me get this straight so u take out the wire to alt to the batt then keep the the wire to the batt to power post then a new wire 4awg alt to the power post so there will be 2 wires going to the power post the new 4awg and the 6awg and by power post u me were all the fuse are right? i know zzp sales the wire stuff but does it come like the set up u have thanks
The power post on my car is on the fender behind the battery. It is red. ZZP sells the cable (I hope it's right). I got a "prototype" and had to modify it.
BTW, 93-97 and 98+ are different.Robert - owner www.FirebirdV6.com/CamaroV6.com
Raven
by fishinI usually have to double, triple my headlight switch for them to come up on my 97 Firebird. I cleaned all connections. Could it be the headlight switch...4 weeks ago
