ok so idk what to do. ok well this is what is goin on im not getting any turn lights or brake lights on my right side. now if i turn my parking light on all lights come on just fine. if i press the brake i lose all the lights on the right side and still no turn lights. where should i start
tail light problem
Re: tail light problem
You have a bad ground most likely caused by a bad light bulb socket.
Mine did the exact same thing and it turned out to be bad sockets for the lights. I bought new ones and the problem is solved.
To test this you can touch a good ground wire to the base of the bulb and you will see it will turn on.
