i have a 95 camaro that i need to take the window motor relay so i can put it in my 97 bird. first off, will that work? im pretty sure it would seeing as they are "the same car". second, where is it located and what might it look like. i havent taken the door panel off yet and im sure its obvious i just dont feel like doing it until i know for sure. if someone could give a diagram or a good description im sure it would be easy. thanks.
EDIT: i just found out i dont need it anymore so im all set
to the best of my knowledge the relay isn't in the door panel...unless your talking about the actual switch??? ...The only relay I can think of that it might have it in the fuse block....now the window motor itself does have a heat controlled automatic cut-off switch to aviod burning your car down, which is also the main reason these window motors go bad so often...otherwise
thanks. as i said i dont need it now. the guy at the shop told my dad he needed one but they dont make them anymore, but as i was doing it i called my dad and he said he got one. if you would like ill find out what he was talking about and tell you, seeing as you are confused like me, lol.
