I noticed the other day that when the fan turned on at 160 like it was supposed to do but then it turned off a minute or so later. I noticed that the car was running at about 210/215 degrees I checked the fan and it was running Ok,nice and strong....Does anyone know what this might be?
cooling fan
Re: cooling fan
Ok, so do a manual fan switch, the hypertuner didnt work, make a cheap fan switch and install it, works fine for me :)
EDIT: Incorrect installationLast edited by FirebirdGT; 08-15-2007, 01:51 PM.*Matt
Re: cooling fan
Originally posted by StrtRacer98Ok, so do a manual fan switch, the hypertuner didnt work, make a cheap fan switch and install it, works fine for me :)
Correct installation
http://forum.camarov6.com/showthread.php?t=77114
.Robert - owner www.FirebirdV6.com/CamaroV6.com
Raven
Re: cooling fan
Originally posted by FirebirdGT
There may be "other" ways to do it like you listed but its not incorrect, Robert.
EDIT: I read your page, and it says its not wired correctly.
But
I have a Low speed fan, on low setting
I have a High speed fan, on high setting, and
when the switch is off it works as normal operation, works ok for meLast edited by StrtRacer98; 08-15-2007, 03:12 PM.*Matt
Re: cooling fan
Originally posted by StrtRacer98I dont know why it's an incorrect installation, it worked fine for me and a handful of other members.
But
Your SPST switch only grounds either the green or dk blue wire.
Grounding only the Drk Blu wire will result in only the RH fan operating at high speed. For both fans to operate on high speed, BOTH relay leads must be grounded.
Your switch may "work" but it is NOT correctly installed.
Raven
