My speedo dont work But my rpm do i have already tested my Speed sensor it is great Can someone else help me ????????:D :D :D
Speedo dont work
Re: Speedo dont work
Check to make sure your odometer and trip meter are reading (climbing). If so, there's a slight chance that it's a bad connection somewhere. If the odo and trip meter aren't changing, then you're proly gonna have to replace the cluster and/or the PCM.
Also, you may wanna have the car scanned for any codes. If you've got a B1000 code that's either the EBCM, the ICP (gauge cluster), the PCM, or the SDM. Chances are, it'll be the cluster. Borrow a gauge cluster from another fbody friend in the area and see if that fixes the problem. If it does, get one at a junk yard, or ebay, or on the boards.~Chris<br />1999 Hugger Orange Camaro<br /> <a href=\"http://www.cardomain.com/ride/273836\" target=\"_blank\">http://www.cardomain.com/ride/273836</a> <br /><br />†…faith…hope
