does that plug and play wiring harness from intense racing work on our fbodies or will i have to do the wiring?
Meziere Electric Water Pump wiring
Re: Meziere Electric Water Pump wiring
should work with our cars as well, I see no reason why it wouldn't
a friend of mine said he would never buy an electric water pumpm because there is no indication as to when they are going to go bad. They just stop working with no warning. Is this really a problem? website says the pump is good for 100k miles
Can't comment on the plug and play harness, but they're straightforward to hook up with a standard relay circuit if you know anything about wiring. And yep, they do look pretty sweet\'98 Camaro V6<br />Appearance... pleasing<br />Performance... just a little extra air.
by ssms5411About a week ago noticed my brake lights not working also Hazards not working. Installed new brake switch and still not working, checked fuses and what...1 day ago
