Power Accessory - FirebirdV6.com/CamaroV6.com Message Board
Power Accessory
  • Power Accessory
    What is the easiest way to tap the 12 volt accessory power output. I have a 2002 camaro and alot of electronics: Radar detector, GPS Cell phone etc. I hate having to plug everything into the outlets. I want a way to conceal the splice. I know for the early 4th gen had an extra acc tap in the console but i cant find that writeup now. Any help would be appreciated.
    Re: Power Accessory
    You can go off a fuse in the fuse panel, or you can tap into the 12V power going into your radio, or run a power wire from your battery into a distribution block and wire everything to that...
    many options.
    *Matt
      Re: Power Accessory
      I tapped into the yellow power (hot in run - retained) wire going to the radio and lighter black ground wire for my radar detector. See the wiring diagram on my site for that and my other electrical mods.
      http://shbox.com/accy/Accessory.html
      Raven
