hey guys i have a 94 camaro and my foglights do not work. anybody know a way i can chekc to see the problem relativly easy? thanks guys
Foglights
Re: Foglights
first thing I would do is check the relay in your fuse box under the hood. Take one of the other relays and move it to the fog spot temporarily and see if your fogs light up. When i bought my car, my fogs wouldn't turn on with the switch, and the relay was the problem. I assume it's fairly common, because the one i replaced was already aftermarket. Could also be that both are burnt out.
Re: Foglights
Turn your parking lights on at the very least or even your headlights, then try flipping the fog light switch. I don't know how it is with everyone else, but with mine, either the parking lights or headlights have to be on for the fog lights to switch on. btw, mine's a 93.Originally posted by LETZRIDEI've never touched a rear end before
Re: Foglights
Originally posted by turbohead2332Turn your parking lights on at the very least or even your headlights, then try flipping the fog light switch. I don't know how it is with everyone else, but with mine, either the parking lights or headlights have to be on for the fog lights to switch on. btw, mine's a 93.
Re: Foglights
It's easy to miss, it's on the side of the inside of the box cover. I went ahead and snapped a few shots for you.. Not the best quality but it's dark and i didn't want to be out in the cold for longer than i had to :P
^^ pretty obvious i've replaced it as it's a different color than the rest.
Re: Foglights
Originally posted by cam98arohe is saying the light on the switch comes on, that light only comes on if the foglights "think" they are onRobert - owner www.FirebirdV6.com/CamaroV6.com
Raven
