I just picked up a a pilar gauge cluster to get the ball rolling on my nitrous install... has anyone installed autometer trans temp, A/F, or fuel pressure gauges before? any help/advice is greatly welcomed
3 gauge A-pillar install, help
Re: 3 gauge A-pillar install, help
They are really easy to hook up. I dont have time to explain it right now, but when I get home from work I'll post some info. PM me if I forget.
BTW, is the A/F gauge a wideband?Last edited by Shodown; 11-14-2007, 08:25 AM.sigpic
1997 Camaro RS A4
2006 Chevy Colorado
2003 Kawasaki Ninja ZX6-R
Assuming you have all electric gauges this is easy.
For a 12V power source...look behind the fuse panel on the drivers side, there are 2 unused fuses: accessory and battery. Put a male quick connect on one power wire from the gauge and plug it in to either one of them. I used both for my gauges.
For a ground, just piggy back onto the black wire on the headlight switch.
As far as the senders are concerned...
For the nitrous sender:
Put it inline with the bottle and the solenoids using a gauge adapter.
For the fuel sender:
Cut the fuel line and put in a T fitting.
Or....
If you have a wet nitrous kit, using another gauge adapter, just put the sender inline with the fuel solenoid right before the FPSS.sigpic
1997 Camaro RS A4
2006 Chevy Colorado
im running a dry shot, what size t fitting should i get, and what is that attached to the t-fitting? im assuming its a fuel pressure sensor, but i want to be sure before i go cutting my fuel line... and if it is a FPS, then where can i get one that will work with my setup?
thats all my questions... for nowLast edited by 00 Silver 6; 11-15-2007, 05:17 PM.2000 Camaro 3800 A4
Im not sure on the size of the T fitting. Look up the size of your fuel lines in a Haynes or Chilton manual.
Then pressure sender/harness comes with the gauge (it should anyhow).sigpic
1997 Camaro RS A4
2006 Chevy Colorado
