I just picked up a a pilar gauge cluster to get the ball rolling on my nitrous install... has anyone installed autometer trans temp, A/F, or fuel pressure gauges before? any help/advice is greatly welcomed
3 gauge A-pillar install, help
Re: 3 gauge A-pillar install, help
They are really easy to hook up. I dont have time to explain it right now, but when I get home from work I'll post some info. PM me if I forget.
BTW, is the A/F gauge a wideband?Last edited by Shodown; 11-14-2007, 08:25 AM.sigpic
1997 Camaro RS A4
2006 Chevy Colorado
2003 Kawasaki Ninja ZX6-R
Assuming you have all electric gauges this is easy.
For a 12V power source...look behind the fuse panel on the drivers side, there are 2 unused fuses: accessory and battery. Put a male quick connect on one power wire from the gauge and plug it in to either one of them. I used both for my gauges.
For a ground, just piggy back onto the black wire on the headlight switch.
As far as the senders are concerned...
For the nitrous sender:
Put it inline with the bottle and the solenoids using a gauge adapter.
For the fuel sender:
Cut the fuel line and put in a T fitting.
Or....
If you have a wet nitrous kit, using another gauge adapter, just put the sender inline with the fuel solenoid right before the FPSS.sigpic
1997 Camaro RS A4
2006 Chevy Colorado
im running a dry shot, what size t fitting should i get, and what is that attached to the t-fitting? im assuming its a fuel pressure sensor, but i want to be sure before i go cutting my fuel line... and if it is a FPS, then where can i get one that will work with my setup?
thats all my questions... for nowLast edited by 00 Silver 6; 11-15-2007, 05:17 PM.2000 Camaro 3800 A4
Im not sure on the size of the T fitting. Look up the size of your fuel lines in a Haynes or Chilton manual.
Then pressure sender/harness comes with the gauge (it should anyhow).sigpic
1997 Camaro RS A4
2006 Chevy Colorado
by 187sharkHi all new to the community here. I have a 2014 RS 6 speed manual... and so about a year ago my tail lights got cracked and eventually the plastic housing...5 days ago
by DoodlerHi, everyone. We bought a 97 base model convertible Camaro and someone broke the motor ... Lights were blinking on the dash and that someone ignored the...1 week ago
by ssms5411Still trying to find oil leak on my Camaro, it’s a tough one. I think it is the oil pressure sender myself. Leaking when raving and going into boost....2 weeks ago
