3 gauge A-pillar install, help - FirebirdV6.com/CamaroV6.com Message Board
  • 3 gauge A-pillar install, help
    I just picked up a a pilar gauge cluster to get the ball rolling on my nitrous install... has anyone installed autometer trans temp, A/F, or fuel pressure gauges before? any help/advice is greatly welcomed
    2000 Camaro 3800 A4
    Re: 3 gauge A-pillar install, help
    just take your time and get the wiring right.
    if this is for nitrous...then where is your nitrous gauge?
    WAWA-A-HOLIC
      the trans temp gauge isnt getting hooked up, that spot is being replaced with a nitrous pressure gauge... i have to order it first though
      2000 Camaro 3800 A4
        They are really easy to hook up. I dont have time to explain it right now, but when I get home from work I'll post some info. PM me if I forget.
        BTW, is the A/F gauge a wideband?
        1997 Camaro RS A4
        2006 Chevy Colorado
        2003 Kawasaki Ninja ZX6-R
          no, i thought it was but it turns out its a narrowband... trust me i know how useful those can be...
          2000 Camaro 3800 A4
            Assuming you have all electric gauges this is easy.
            For a 12V power source...look behind the fuse panel on the drivers side, there are 2 unused fuses: accessory and battery. Put a male quick connect on one power wire from the gauge and plug it in to either one of them. I used both for my gauges.
            For a ground, just piggy back onto the black wire on the headlight switch.
            As far as the senders are concerned...
            For the nitrous sender:
            Put it inline with the bottle and the solenoids using a gauge adapter.
            For the fuel sender:
            Cut the fuel line and put in a T fitting.
            Or....
            If you have a wet nitrous kit, using another gauge adapter, just put the sender inline with the fuel solenoid right before the FPSS.
            1997 Camaro RS A4
            2006 Chevy Colorado
              thanks man! :tup:
              2000 Camaro 3800 A4
                im running a dry shot, what size t fitting should i get, and what is that attached to the t-fitting? im assuming its a fuel pressure sensor, but i want to be sure before i go cutting my fuel line... and if it is a FPS, then where can i get one that will work with my setup?
                thats all my questions... for now
                2000 Camaro 3800 A4
                  Im not sure on the size of the T fitting. Look up the size of your fuel lines in a Haynes or Chilton manual.
                  Then pressure sender/harness comes with the gauge (it should anyhow).
                  1997 Camaro RS A4
                  2006 Chevy Colorado
