Power Locks don't work - FirebirdV6.com/CamaroV6.com Message Board
  • Power Locks don't work
    Hey yall, my power locks stopped workin a while ago and now that my car's on blocks for the winter i'd like to try to fix that. They didn't just not work one day, for a few days prior to them not working they seemed to lack power, meaning they would push the lock about half way out and i would have to do it a couple times or just unlock it with my hand. Well a few days later it stopped working at all (maybe this will be helpful when it comes to troubleshooting) anyhow, where is a good place to start for fixin the prob? fuses? wiring? should i take the thing apart? i'm just lookin for a place to start and a couple ideas of where to go from there. Thanx
    Re: Power Locks don't work
    ALWAYS check your fuses first.
    Inside the car, on the drivers side there is a fuse panel, remove cover and check for blown fuses.
    PWR ACCY 15amp
    COURTESY 20 amp
    *Matt
      PWR ACCY 15amp
      COURTESY 20 amp
      fuses are fine, whats next? =)
        Okay next easy thing to check, pop the switch panels off your door and make sure the plug / harness is on correctly.
        If you have a multimeter check for voltage and ground...
        *Matt
          so check to make sure no wires are detached or broken ect ?
          and do i have to pry both of them off? basically if one doesnt work does that mean they both dont work?
          any ideas?
            id really like to know beforei take both of them apart =(
              id check both just to be safe, its super easy to take apart. shouldnt take long
              *Matt
