ABS/TCS Woes - FirebirdV6.com/CamaroV6.com Message Board
ABS/TCS Woes
  • ABS/TCS Woes
    My "ABS", "Low Trac", and "Brake" indicators are beginning to anger me.
    When they start to flash I can hear the abs relay clicking, but it isn't activating the brakes. When I press the brakes a few times the lights go out, then when I start to move the abs light comes back on. So it is sensing low traction conditions, but after that it is failing. Does anyone have a wiring diagram for the abs system on a 97 camaro?
    It does this when I spin one or both of my rear wheels, so do I have TCS or what?
    Re: ABS/TCS Woes
    Do the lights come on when your not spinning your tires?
    1996 Chevrolet Camaro
    1995 Buick Park Avenue Ultra
    --Appearance Moderator--
      Re: ABS/TCS Woes
      The ABS light is always on (unless I pump the brake pedal while stopped), the brake and low trac lights come on or flash together while driving if it is slippery out or if I hit a large bump.
        Re: ABS/TCS Woes
        Check and make sure the thig is grounded. Mine was loose and it would go off and on all the time.
