Installed Clear Markers (Pics)
Re: Installed Clear Markers (Pics)
i actually have the battery disconnected right now, but when i connect it i'll let you know how they look! One was a little loose goin in but they're in there. For 2 bux you cant go wrong with the leds though, the red bulbs they send with the markers are red and very big. these led's are small and look great imo. thanx for the idea for them btw shlotzky!
Originally posted by tkoforpresidenti actually have the battery disconnected right now, but when i connect it i'll let you know how they look! One was a little loose goin in but they're in there. For 2 bux you cant go wrong with the leds though, the red bulbs they send with the markers are red and very big. these led's are small and look great imo. thanx for the idea for them btw shlotzky!
Originally posted by TheGr8SchlotzkyNo problem. Keep in mind LEDs are essentially diodes, and only allow current to flow one way, so if either/both LEDs don't light up when you hook the battery back up, you will need to flip them around in the socket.
good thing its super easy to take the markers out =)
EDIT: Learned tha the hard way in electronics class
LED'S = good choice. The "red" bulbs that came with my clears, illuminated pink. I kid you not, my wife busted out laughing when I showed her. I just put white bulbs in them bad boys. My now defunct Camaro is black, the clears front and rear went well with it.
by ssms5411So my truck is finally getting some work done, after 17 years, Oil pressure sensor went out and it’s located under the lower intake manifold. Have to...3 weeks ago
