ok my headlights dont want to go down when i turn them off. but i also noticed that my headlights are trying to go up and down when i arm and disarm my alarm and it has never done that b4 so i was like wtf how can it start doing that out of no where?
firebird headlight problem
Re: firebird headlight problem
There is a gear inside the motor that has teeth that wear out. You can replace the motors or replace the plastic gear inside with another cheap plastic gear or get a brass gear instead. It freaked me out at first... if you hear a grinding noise, its the teeth grinding when the gear is spinning. I will find you a link...
the gear
http://www.bfranker.badz28.com/headlightfix/index.htm
how to
http://www.bfranker.badz28.com/headl...earinstall.htm
It messes with the computer... When my gears messed up, everytime I used my keyless entry the headlights would go up and back down. Everyone has the same problem with the same results. My headlights would go down fine, but they made a grinding noise for a few secs and popped up and down when using keyless remote.
