alright so when turn on my car sometimes the turn signal/daytime running lights dont come on and sometimes they do, any idea why??...also when they do turn on and i also turn on my headlights the turn signal lamps dim a little, is that normal???? my batteries ok, at least thats what it shows me...could it be my alternator???
turn signal help/electrical problem
Re: turn signal help/electrical problem
check for a blown fuse (fuse panel is located on the driver side dashboard, door will have to be open to get to it)1999 v6 Camaro M5
Automatic to Manual converted
Pacesetter Headers, 2.5" Custom True Duals with X-Pipe and Magnaflow Bullet Muffers,
!cat, Intake, 3.42's with LSD, MSD Wires, Drilled/Slotted Rotors, Hurst Short Shifter, Tuned PCM
Originally posted by firebird19_99according to bigrian its normal.....i thought so, but needed to be sure so im gonna check the fuses anyway.....thnx for the help
thinking back on it, if it was a blown fuse it wouldn't work at all. like it was said before, probably a bad ground or a loose wire1999 v6 Camaro M5
