Under Hood Lighting - FirebirdV6.com/CamaroV6.com Message Board
Under Hood Lighting
  • Under Hood Lighting
    I recently have been doing alot to my car with LEDs, mostly interior stuff with 5k mcd 3mm blues. I just purchased some of those really bright 20K mcd 5mm white LEDs cuz I am going to be doing the interior lights and the license plate lighting with them.
    Was wondering if anyone here has ever done any custom lighting for under the hood with these babies, I figure you space out a good bit of them and it should be like daylight under there :cool: Maybe hook em up to a mercury switch or a pin switch or something, what yall think??
    Re: Under Hood Lighting
    have them in white under my hood looks cool but i only ended up using about 10 white leds space out just enought to get a good glow nothing drastic
      You can go with 3 watt LEDS will take alot less but costs more. You could easily mount a switch if you wanted, either manual or automated one when you open the hood . I have replaced most of the lights on the inside of my car with red leds. I like the look but is harder to find stuff at night.
        Sweet, yea, just mount a little toggle switch somewhere under there, probably just do that. Do you have a link or something for those 3 watt LEDs at all??
        So Crunk, what were the rating of those LEDs you used?? Is the light your getting with them not enough to do anything work wise say at night?
          Here is one place that sells them and has info, they have up to 5 watt LEDS. They are very bright, alot of flashlights use them. You can also find them on e-bay a bit cheaper.
          http://www.theledlight.com/LuxeonLEDs.html
            Cool, thanks alot...
              Sounds like a great project. Please post pics after it is completed.
                umm not so much as working on the engine bay at night but bright enough to make the chromed and polished things stand out
                  oh they are like 17,000 mcds
                    heres a pic of my old set up with blue leds white ones are brighter "cell phone pic"
                      those blues look sweet...
                      as per Kevin01's suggestion, I think I am going to be ordering 4-5 of those 3 watt Luxeon white LED's... the LXHL-PW09's on this page... http://www.theledlight.com/highdome_3watt.html
                      just need to figure out how to wire them, probably very similar to standard LEDs...
                      Those suckers are BRIGHT!!
                        Let us know when you finish this!
                        1998 Red T-top V6 Camaro
                        - K&N Filter, Pacesetter Headders, MagnaFlow 2.5" Hi-Flo Cat, FlowMaster 80 Series, PowerDyne Supercharger@9Psi More 2 Come
                          6 days ago
