Mornin' all, hoping someone can help out here. On my '96 Firebird tailight assembly (pass side) the inboard 1157 light (there are two in each housing)will light up only one filament when the marker lights are off and the brake is applied, but then goes out when the running lights are on and the brake is applied. If it's just the socket, that'll be no big deal, but I'm not quite sure and wouldn't want to throw away the time ordering if it doesn't cure the problem. As far as I can see (up to the harness assembly, all wires are physically ok. Any help would be greatly appreciated. Thanks.
Looking for a wiring guru
Re: Looking for a wiring guru
Just did. Same thing happens with a different bulbe. What it's doing is lighting the single filament only when the brakes are applied. When the lights are on, however, the light goes out when the brakes are applied
This happened with me on my '96 bird. The brighter filament just wouldn't light at all, and would occasionally go out in fact. Went through three bulbs checking it, finally just got a replacement socket, wired it up and I haven't had the problem since, and that was 2 yrs ago...Y87 Package
MANUAL CONVERTED, Pro 5.0 Shifter
Pacesetters, Magnaflow Cat, Cutout, Flowmaster
MOGOB APPROVED!
BONE APPROVED!
VANBIBBER APPROVED!
KRISTEN APPROVED!
Vice Prez.
Team Black...TEAM EMO
Come on kids! Get a Calendar!
I'm going to have to agree with it being the socket. Happened to mine a while back. My left blinker stop blinking (just stayed solid). Traced it back to the rear drivers side tail light. One of the bulbs wouldn't light up properly. Tried changing it out several times to no avail. Finally just took the socket apart, and saw that the negative terminal inside was corroded almost completely. Took out that terminal (along with about 2 inches of wire thats attached, replaced it with another one I had, spliced the wires back together and viola. Your best bet is to just buy a new socket from an auto parts store, and splice it in. You've already done the hard part of finding the bad socket, so the rest should be easy going.<b>1995 Pontiac Firebird</b> || 3.4L V6
BE FOREWARNED THOUGH.
I got my replacement socket at an Advance Auto Parts and It was very strange. The socket actually goes in at a different angle, so that when it is locked in place, it doesn't face the wires down like the OEM GM/Delco version. These sockets point the wires at a strange 135 degree angle up. It's very awkward. If I had the choice, I'd go OEM replacement, but that's just me.Y87 Package
MOGOB APPROVED!
BONE APPROVED!
VANBIBBER APPROVED!
KRISTEN APPROVED!
Vice Prez.
by ssms5411So my truck is finally getting some work done, after 17 years, Oil pressure sensor went out and it’s located under the lower intake manifold. Have to...8 hours ago
