would anyone happen to klnow what a good set of fog lights or running lights would be for a 97 firebird? and what is the best place to run the wires?
Re: fog lights or running lights
Did you have the factory ones at one point? It's a lot easier to replace them than completely wire up new ones. As for the replacements, it's personal choice.
Fog lights: not as powerful, wider beam, usually attached to low-beams
Driving lights: powerful, narrow beam, usually attached to high beams (might get you pulled over/ticketed for them if you attach them to low beams)
There are several write-ups (search for those) on how to mount aftermarket fog lights.
no, it didnt come with them from the factory, but the kid we bought it off of had a pair on, but looked stupid cause they didnt fit right and plus he had the wiring wrapped around the sway bar, so i tore those out as soon as possible
I was trying to find a pair that was split, having the fog lights and driving lights by the flip of a switch
I found these split ones that i dont think that would look bad,
http://www.realtruck.com/productline...og_lights.html
I also found a cheap pair of fog lights at walmart that sorta look like the oem rectangle ones on the camaros that didnt look bad
