Ok this is weird my signal lights are working but they don't blink!. :mad: It was working just fine then they like just stay litup as if iam hitting the brakes and theirs alight out in the back.
Can anyone offer a quick fix or suggestions of what it could be?.
I had somewhat the same problem, but it was only on one side, so I replaced my bulbs and after that it cleared up. If your blinkers aren't working on either side, though, I would imagine you would need to change the blinker mechanism in the dash under the steering shaft. There is a good picture in another thread, if you can search for it.
The "flasher" relay is bad, it costs under $10 from a parts store.
Under your dash, remove the panel directly under your steering wheel.
To access the flasher, it is to the right of the steering column, unplug and replace with a new one.
Very cheap part and easy to replace. Just make sure you change the right one because there are two of them. One for the hazards and one for the signals.
Hello Everyone,
I just want to make sure that I am reading the above correctly. My turn signals flash front and rear on my 99 v6 firebird, but the side markers do not flash. I find it problematic as the design to the front of the car prevents cars from the side to see that I am turning. On the highway for instance. Does everyones side markers not flash when turning? Or is my relay bad too? (like it is only connecting the front and rear and not the sides due to a bad connection in the relay?)
