Blinkers aren't working right. - FirebirdV6.com/CamaroV6.com Message Board
  • #31
    Re: Blinkers aren't working right.
    went to autoparts store this afternoon. Flasher was $14. I said if this does not fix my problem, can I bring it back for a refund....said NO....he said this flasher either works completely or not at all. ...so this part replacement will not solve my problem.
    • #32
      FIXED today...flasher was not a solution.
      • #33
        Yeah, usually anything that electricity runs through the parts stores won't take them back.
        I have a problem with my old truck's rear driver's side blinker myself. At first I thought it was the light bulb. I replaced it and it still wouldn't blink. I checked and see if there's any currents flowing through it and no there isn't.
        Did yours have this same problem where only one blinker wasn't working?
        I bought the Flasher Relay too, but I haven't installed yet. I think they gave me the wrong part, unfortunately I opened it already, plus I wanted to check the grounds for it first.
        • #34
          Mine's wonky. At first, the left rear turn signal was intermittent. Now, neither rear comes on at all. I checked the bulbs, the rear wiring, all good. The fronts at least come on when I work the lever manually. I'm not surprised considering nearly 311,000 miles, but there's an easier fix: http://www.summitracing.com/parts/up...FQmSaQodUlMNtQ. $16, and you can find them in black plastic. Saves messing with the airbag steering wheel to replace the switch in the column.
