for the past couple of weeks, my passenger side headlight will not go up or down, the motor is fine and the fuses arent blown. and when your hit the unlock or lock button the driveers side headlight goes up and then right back down. Does anyone know where the problem might be?
head light problem
Re: head light problem
I had something similar happen. Whenever I hit the keyless entry, one headlight would act funny, come up, then go down. I found out that it was the headlight "transmission". Basically, where the knob is to manually flip it up or down. I replaced that unit and it's been fine ever since. Just sounded similar. Hope this helps.
Originally posted by steddy View PostI had something similar happen. Whenever I hit the keyless entry, one headlight would act funny, come up, then go down. I found out that it was the headlight "transmission". Basically, where the knob is to manually flip it up or down. I replaced that unit and it's been fine ever since. Just sounded similar. Hope this helps.sigpic
thats why you should have gotten a camaro... :)#1:1999 pewter metallic y87 rs A4 camaro.check out the pics on the link below<br />#2:Bright red 1979 Pontiac Trans Am. Brand new 400 cubic inch Pontiac Motor. All work done by me, except the engine work.<br /> <a href=\"http://www.cardomain.com/ride/2216133\" target=\"_blank\">http://www.cardomain.com/ride/2216133</a>
by DoodlerHi, everyone. We bought a 97 base model convertible Camaro and someone broke the motor ... Lights were blinking on the dash and that someone ignored the...4 hours ago
