alright so my antenna decided to fuk up 2day....i can hear the motor working but the antenna doesnt move at all.....idk wat it could b...whether its the antenna or the motors pretty much dead...any help?? thnx
antenna problem
Re: antenna problem
you can try to give it a little help. Turn the headunit on and when the antenna motor is trying to push the mast up.... try to grab a hold of it and help it up. It might be stuck a little or something.
But likely it's just toast. Any universal power antenna should fit fine. I bought mine from RKSport back in the day. $100 I think. Surely you can find them for much less. Buy one that has a replaceable mast. In case it ever gets bent, you just unscrew and replace. Vice buying a whole new motor too.
Re: antenna problem
Originally posted by bigbrian442 View PostReplace the antenna. Thepartsladi on eBay sells the GM antenna for $105 plus shipping.
The antenna is on a long plastic strip that winds up and down. It's got teeth on it so that it's like one long gear. They get stripped very easily, and that's what happened. Kind of like the how the headlight motor gears get stripped. I didn't feel like forking over any more cash for it since it will likely happen again. So I just took the whole antenna mast out of the motor assembly. Now I just have the mount on the outer body where the mast used to go though. Capped that off with some aluminum that I cut up and spray painted black. You can't even tell it's missing now. Best part is that i still get all the local radio stations clear as day.<b>1995 Pontiac Firebird</b> || 3.4L V6
Re: antenna problem
Re: antenna problem
Originally posted by firebird19_99 View Postthnx guys....yea i dont feel like payin a 100 bucks for a new one so im going to look into those universal ones.....did u have to cut anything to get it in??
Re: antenna problem
Originally posted by josh98bird View PostMine bolted right up with the existing one... took 5 minutes. The worst part was placing the antenna on the side of the fender through the existing hole with the assortment of rubber pieces you are given. In other words, piece of cake!
Re: antenna problem
Originally posted by firebird19_99 View Postwouldnt happen to have the url orr website where u got it?? looked around and their all like 50-120
I saw some on amazon for 25 dollars but they have no reviews. Looks up the Legacy antenna... I don't know what brand mine is, but any should be pretty good. $50 is still better then $100
Hey guys. For starters I’ve always been a big car guy, I love all types of cars and can appreciate all types of engineering. I’ve always been a Chevy...1 day ago
by ssms5411Getting a massage saying invalid interface, haven’t used it since last year probably November. First time in 23 years I had a problem. Going to get...3 days ago
