Interior Lights. How Many and What Kind? - FirebirdV6.com/CamaroV6.com Message Board
  • Interior Lights. How Many and What Kind?
    I do not post much on here but I will try to make it simple.
    I want to change all my bulbs out in the interior of my 1999 camaro.
    After visiting a couple of sites to buy the LED's all I get for reference is the Sylvania list that tells you what type bulbs there are in your vehicle. However, they do not tell you how many and they are just a little vague on the specific location.
    What I want to do is replace ALL of my bulbs in my interior and only do it once. I do not want to have to go back and order more bulbs and take my dash apart again because I did not have enough to replace them all. I know that some are like 161's and 194's etc.... But how many are there?
    Also I saw a thread where someone replaced the bulbs behind the AC knobs and the others in that area by sanding down the LED's and other things to get them to fit. Do they not make direct replacements for these bulbs in this area?
    Anyway, I have looked on search engines and have not found any schematics or anything like that so this is my last resort.
    If this has been posted somewhere else please direct me but if not can someone please help me out. I really want to do this and I have found a couple of great sites to get my LED's I just need to know how many I need.
    Thanks!
    Re: Interior Lights. How Many and What Kind?
    99 camaro - off the top of my head the rear view mirror is a 211-12 festoon bulb. you will need 2. The gauge cluster you will need i think it was 5-7 of the #194's. The Hvac controlls you will need 2 #74 bulbs. The little courtesy light on the door handles you will need 2 of the #74 bulbs. The shifter is 1 #74 bulb. The headlamp control people usually solder in a led since there is no replacement. The dome light is i believe a 561 bulb you will need one of them. The only place i ever found that was a place called Dav electronics. google it. I think thats about all. let me know any more questions
    1997 Camaro LS1 RS
    1994 Camaro - Sold
    1999 Trans am Vert - Sold
    A Few Mods....
      As for how many and exact locations, I really don't know. I haven't heard about replacing the bulbs behind the A/C controls....
      These Part#'s are from a 99, But should be the same throughout the years.
      ____Exerior Lamp Usage____
      Back-up Lamp-----------------------------3155
      Back-up Lamp (Export)--------------------P21W
      Fog Lamp (Chevrolet)---------------------894X
      Fog Lamp (Export)------------------------H3
      Fog Lamp (Pontiac)-----------------------880
      Front Side Marker Lamp-------------------194
      Headlamp Low Beam (Chevrolet)------------9006
      Headlamp High Beam (Chevrolet)-----------9005
      Headlamp Low Beam (Pontiac)--------------H4703
      Headlamp High Beam (Pontiac)-------------H4701
      High-Mount Stoplamp (Chevrolet Export)---W16W
      High-Mount Stoplamp
      (Chevrolet and Pontiac Domestic)---------921
      License Lamp-----------------------------194
      License Lamp (Export-Europe)-------------W3W
      Park and Turn Signal (Chevrolet)---------3157k
      Park and Turn Signal (Pontiac)-----------3157NAK
      Park and Turn Signal (Export)------------P27/7WLL
      Rear Fog Lamp (Export)-------------------P21W
      Rear Sidemarker Lamp---------------------194
      Side Repeater Lamp (Export)--------------W5W
      Taillamp, Stop/Tail----------------------3057
      Taillamp, Stop/Tail (Export)-------------P21/W5
      Tailamp, Stop, Turn Signal (Pontiac)-----3057
      Taillamp, Turn Signal (Chevrolet)--------3057
      Taillamp, Turn Signal (Export)-----------P21/W5
      Tailamp (Fill In)------------------------194
      Taillamp (Fill in) (Export)--------------W5W
      ____Interior Lamp Usage____
      Ashtray Lamp-----------------------------194
      Automatic Transmission Indicator Lamp----73
      Dome Lamp--------------------------------906
      Front Side Door Courtesy Lamp------------74
      Heater and Air Conditioning Control Lamp-37
      Instrument Cluster Lamp------------------161
      Instrument Panel Compartment Lamp--------194
      Reading Lamp-----------------------------212-2
      Reading Lamp (most 2001+up)--------------194
      Rear Compartment Lamp (Convertible)------562
      Rear Courtesy Lamp (Convertible)---------562
      Turn Signal Indicator Lamp---------------161
      Warning/Indicator (Chevrolet)------------161
      Warning/Indicator (Excluding Turn Signal Indicator) (Pontiac)------PC74
      Red 96' A4 Firebird
      Audio Audio and Autotek
      Check it out here!
        Just found this. Probably help a little....
        http://www.lastofthebreed.com/Installs/InstallIndex.htm
        Red 96' A4 Firebird
        Check it out here!
          Tom rs --- I have seen most of the other things everyone posted but you helped A LOT!
          You gave me exactly what I needed. The number of lights I need to buy!
          Also thank you very much because DAV electronics makes the THIRD place I wanted to find for LED's. I had the site a long time ago but I never saved it and I couldnt remember the name. THANKS!
          BTW these are the others and I believe one has an alternative to the 561 just FYI! I hope these help the others wanting to convert their lights.
          www.superbrightleds.com
          www.v-leds.com
          96firebird311, thank you anyway but all you gave me was a paste of what sylvania had. Your effort is appreciated though.
          Last edited by hybridx; 04-04-2008, 07:29 PM. Reason: forgot to name who i was thanking
            Oh yeah BTW anyone who can add any info I would greatly appreciate it!
              No problem. let me know if you need any other info
              1997 Camaro LS1 RS
              1994 Camaro - Sold
              A Few Mods....
