I know, this sounds pretty simple. I saw a couple things on LED lighting for the interior and found a few LEDs that were the "barrel" type that would just plug and go. They fit a little loose, so I just spot soldered them so they won't rattle around. In order to do this, I disconnected the electrical lead and removed the mirror from the windshield. Ok, I get the LEDs put in, I check them with a used motorcycle battery I have to make sure that they light. HUGE light! All's going well. I put the connector back on the mirror. No lights. I take it back off again and put a meter to the electrical lead. Shows 12.7 - 13.2 volts (should be plenty). Now, I know the lights light up with 12v put to them directly at the pins where the connector goes and I know that there's 12v at the connector, but when I put the connector on the mirror, no lights. Anybody have any ideas out there before I send the mirror through the windshield? :mad:
Rear View Mirror Won't Light
Re: Rear View Mirror Won't Light
The only time I've seen issues like this is usually in higher-end cars. They can sense the load place on certain wires. If you tap onto them, it just shuts it down. Doesn't blow a fuse..... just doesn't send power to it.
I seriously doubt this is the issue with the f-body..... but there is no other reason if the info you have given us is correct.
Yeah, got home yesterday and hurriedly started getting going on the project. At the point where I was yesterday, I didn't realize that maybe I had put them in backwards (reverse polarity). When I walked away and wrote the thread, I was just at that point, without realizing that maybe through all the twists and turns and removing the mirror and soldering this and tightening that, I may have screwed the polarity up. Anyway, walked away, sat and watched tv, had a beer, then realized, I may have turned them both around, so off the mirror came again. I turned them, re-soldered and bam! There they are. My apologies for the mometary lapse of reason and great thanks to 96firebird311 and thegr8schlotzky for the help and replies. You guys :rock:
