fuse size - FirebirdV6.com/CamaroV6.com Message Board
fuse size
  • fuse size
    I'm helping my friend install an rf modulator into his mazda protege so he can listen to his mp3 player through the car stereo without all the bs of fm transmitters blah blah blah. anyway, we got it all hooked up except for the power supply. I can't find any information about it and don't know what size fuse to use. 10 amp would probably be enough...I don't know.
    also on the power supply thing it has 3 wires? red black and yellow. Red=hot, black=ground, yellow=? extra ground? I don't know, we're also trying to figure out the best way to wire it. Pretty much decide on going through the fusebox, but can't find a fuse diagram for his car, pretty annoying.
    input?
    Re: fuse size
    Yellow is constant 12V
    Red is ignition 12V
    10amp is plenty. Use a 5.
    Red 96' A4 Firebird
    Audio Audio and Autotek
    Check it out here!
      Re: fuse size
      Red is ignition 12V
      gotcha. So should I hook them both up? or just one
        Re: fuse size
        Both. Yellow is your power. Red just triggers the unit on when you turn the key.
        Lounge Moderator
