well since i got my speakers installed i noticed my little lights that light up the power window switch panel dont come on. im thinking they either...1. didnt hook them back in.....2.blew the bulbs.....or 3. blew a fuse. my question is how can i get to these lights(can I without taking the whole door panel off?) and is there a fuse for them and which one?
Window switch lights
Re: Window switch lights
You can "pop" the switch panel. This panel has your power door locks or power window switches if you have them.
A little nitch is in the back of the panel. Get a flat head screwdriver and twist it while its in the nitch. The panel will pop off.
You should be able to get to the bulb from there. You need to twist the bulb and socket to get it out.
Edit:
The first few steps here: http://shbox.com/page/windowmotor.html
should help you out.Last edited by Crazed98Camaro; 07-19-2008, 06:12 AM.
I don't think I've ever seen those lights on my car lit up, on either side. I can't see that little bulb doing much from I'm guessing the hole above the switches. Is there a picture of that light in the dark somewhere?
by DongrossmdI’m new. I actually don’t own a Camaro or firebird. I do have a 2000 Camaro 3.8 fly by throttle and 4l60e. This is installed in a 1980 Triumph TR7...22 hours ago
