ok few problems will first my car doesnt have a blue and green wire why? i only have a green one. sec i tapped into the green wire that has the j. then ran a ground and then to the switch. well nothing. please help
manual fan switch
Re: manual fan switch
Sounds like you're reading the 3.8 fan switch instructions. Here's the 3.4's:
http://forum.camarov6.com/showthread...3.4+fan+switch
Since you only have one fan, it's somewhat different. Same concept, except just one wire instead.~97 3.8L V6 Camaro~
A few things
Only Member of Team Hooker?!?
Originally posted by RadRacer View PostSounds like you're reading the 3.8 fan switch instructions. Here's the 3.4's:
Attach them inside the car to a 2 prong.
One for the power of the green wire, and one for the ground.
whats a 2 prong
Originally posted by RadRacer View Postswitch. just a standard on/off switch. you don't have a hi and lo fan, so no need for a SPDT switch (2 ons, 1 off).
put the fuse on the "hot side", or the side that will be supplying the current. You can check if it's hot or not by hooking up a voltmeter to the wire and a ground. If there's a current then it's hot. As for the switch, you can use it. put the ground in the middle prong, and the hot wire on either the top or bottom prong. This set-up, only moving the switch to the one side will turn on the fan; center and the other side won't do anything. You could also bridge the hot wire from the very top to the very bottom prong, with the ground still in the middle. This way, either way you flip the switch it will turn on the fan, leaving center as off.~97 3.8L V6 Camaro~
A few things
Originally posted by RadRacer View Postput the fuse on the "hot side", or the side that will be supplying the current. You can check if it's hot or not by hooking up a voltmeter to the wire and a ground. If there's a current then it's hot. As for the switch, you can use it. put the ground in the middle prong, and the hot wire on either the top or bottom prong. This set-up, only moving the switch to the one side will turn on the fan; center and the other side won't do anything. You could also bridge the hot wire from the very top to the very bottom prong, with the ground still in the middle. This way, either way you flip the switch it will turn on the fan, leaving center as off.
by DongrossmdI’m new. I actually don’t own a Camaro or firebird. I do have a 2000 Camaro 3.8 fly by throttle and 4l60e. This is installed in a 1980 Triumph TR7...22 hours ago
