manual fan switch - FirebirdV6.com/CamaroV6.com Message Board
manual fan switch
  • manual fan switch
    ok few problems will first my car doesnt have a blue and green wire why? i only have a green one. sec i tapped into the green wire that has the j. then ran a ground and then to the switch. well nothing. please help
    Re: manual fan switch
    Sounds like you're reading the 3.8 fan switch instructions. Here's the 3.4's:
    http://forum.camarov6.com/showthread...3.4+fan+switch
    Since you only have one fan, it's somewhat different. Same concept, except just one wire instead.
    ~97 3.8L V6 Camaro~
    A few things
    Only Member of Team Hooker?!?
      thanks alot the only problem is i dont under stand this part
      Attach them inside the car to a 2 prong.
      One for the power of the green wire, and one for the ground.
      whats a 2 prong
        switch. just a standard on/off switch. you don't have a hi and lo fan, so no need for a SPDT switch (2 ons, 1 off).
        ~97 3.8L V6 Camaro~
        A few things
          shoot man thats the switch i bought. can i still use it? and where do i want to put the fuse on the wire that going to the switch?
            put the fuse on the "hot side", or the side that will be supplying the current. You can check if it's hot or not by hooking up a voltmeter to the wire and a ground. If there's a current then it's hot. As for the switch, you can use it. put the ground in the middle prong, and the hot wire on either the top or bottom prong. This set-up, only moving the switch to the one side will turn on the fan; center and the other side won't do anything. You could also bridge the hot wire from the very top to the very bottom prong, with the ground still in the middle. This way, either way you flip the switch it will turn on the fan, leaving center as off.
            ~97 3.8L V6 Camaro~
            A few things
              thanks it worked great
                good to hear man :)
                ~97 3.8L V6 Camaro~
                A few things
                  My Hptuners stop working
                  Getting a massage saying invalid interface, haven’t used it since last year probably November. First time in 23 years I had a problem. Going to get...
                  15 hours ago
                • Money pit
                  Zzp cams
                  by Money pit
                  Has anyone used zzp gt1 cam if so is it worth the money and time
                  2 days ago
                • thatpewterfirebird
                  2001 3800 s2 firebird
                  by thatpewterfirebird
                  4 days ago
                • Turbo 3800 camaro
                  Where are the videos?
                  by Turbo 3800 camaro
                  6 days ago
                  New Chevele
                  Just saw it on Facebook, looks awesome. The front and rear nice looking....
