Electrical Woes - FirebirdV6.com/CamaroV6.com Message Board
Electrical Woes
  • Electrical Woes
    I went away for vacation to Maine (crappy) from the 19 to today, the 26th.
    The camaro sat the the whole time, was in perfect running condition before she was parked.
    I get home today, go for a ride to see if all is well.
    Put down the windows.
    Go to wal-mart. Put the windows up. I can see the tint mark on my drivers side window. Not usual.
    Leave wal-mart, put windows down. Use the "auto" down feature, but window doesnt make it all the way down, only a very little bit is showing.
    Go to CVS. Window makes it half way up. PCM resets itself. I can tell by only 1 horn honk when locked (I have it set for 2) and when I left, the Speedo went full range.
    Go home, start to diagnose.
    I can turn the car on, put the window up some, then it will stop.
    Turn it off and on again, and can do the same thing.
    Not a putter-slow stop; an ubrupt stop.
    If I push it up to a certian degee, There is a buzzing noise under the dash.
    Push it down and I get one click the first time, then a different one the second.
    Anyone know where the BCM (body control module) is? Could this be the culprit?
    Thanks for your help.
    Re: Electrical Woes
    Pictures:
    Took the Kick panels off, looked, listened. Seems like the buzzing and clicking is coming from the center of the dash.
    What are the cylinders circled in red?
    Other than that, I can feel the pink cylinder viberating when the buzzing happens, so whatever is buzzing is connected somehow to the cylider.
      Re: Electrical Woes
      Well, if its anything to anybody....
      http://www.ls1tech.com/forums/showth...ow+driver+buzz
      Found the problem, window motor went up and died.
      Didn't think this was likely, I mean its only a 35k mile car.
      But she is 10 yrs old.
      Looks like I'll be doing a window motor sometime! Hurah for skinny arms!
        4 days ago
