Anyone running just a hi-speed switch? i'm thinking of doing the mod while I install the nitrous kit, and it seems the low speed would be kind of pointless; main reason I want the fan is to run it in the staging lanes. So, anyone running just one-speed for the fan, instead of using the DPDT switch to have hi and low? Any reason why I shouldn't do it?
Fan switch
This topic is closed.
Re: Fan switch
just run a SPST switch to the high-fan wire, and then ground the switch....should work.Y87 Package
MOGOB APPROVED!
BONE APPROVED!
VANBIBBER APPROVED!
KRISTEN APPROVED!
Vice Prez.
Team Black...TEAM EMO
Come on kids! Get a Calendar!
Re: Fan switch
ya, that's what i'm doin. I just ordered a few switches last night from RS; a covered arming switch, momentary pushbutton, and lighted SPST for the fan.~97 3.8L V6 Camaro~
A few things
Only Member of Team Hooker?!?
Re: Fan switch
Originally posted by Firebirdkid96 View Postjust run a SPST switch to the high-fan wire, and then ground the switch....should work.
NO, NO, NO!!
There is NO high speed fan wire!!
You need to ground THREE relays for high speed on the fans! Relay #1 is for low speed, Relay #2 and #3 with Relay #1 gives high speed.
If you don't have the wiring diagram, or understand how the circuit works, don't mess with it.
.Robert - owner www.FirebirdV6.com/CamaroV6.com
Raven
Re: Fan switch
Originally posted by RadRacer View Postya, that's what i'm doin. I just ordered a few switches last night from RS; a covered arming switch, momentary pushbutton, and lighted SPST for the fan.
NO, SPST switch will NOT work!!Robert - owner www.FirebirdV6.com/CamaroV6.com
Raven
by DongrossmdI’m new. I actually don’t own a Camaro or firebird. I do have a 2000 Camaro 3.8 fly by throttle and 4l60e. This is installed in a 1980 Triumph TR7...22 hours ago
