the problem: when I turn ignition key, the headlighs flip up (and stay up while driving). When I use my turn signals; they headlights flip and down in sync with the signals.
I recently changed the flasher could this be causing it to happen?
Is it bad grounds, and if so how do I clean them?
YES!! the left turn signal does stay on when i turn on my headlights
that one's been giving me trouble for a few months now. I was thinking of taking out the flasher replacement i got from autozone and see if the problem stops. I'm now on my 2nd flasher relay - the first one blew out in 3 days.
So overall, this problem happened a total of 4 starts today. (2 without cranking the engine, just turning ignition on)
I should also add that I did not take the flasher out yet, however i started it twice tonight, and both times no problems.
Ok, now, does this happen with either turn signal, or is it just the left side? Also, do you get the same effect when the hazard lights are on, or only the turn signals?
And just to get things straight, your headlights are popping up, but they are not turning on, correct?
I also realized that I am assuming you have a 98+ firebird with DRLs, is this correct?
When I start the ignition the headlights both pop up, but the light bulbs do not come on.
When I turn the switch to turn on the headlights only the left turn signal stays illuminated on the dashboard.
Sorry, I didn't think to check the hazards... I'll Try it though when it happens again (I'm at work today).
And yes, I have a 98 firebIrd with DTRs. However the left signal has been giving me problems for awhile. The bulbs always burn out within 2 days of replacing them. I assumed it was due to moisture.
Yes, the bulbs burning out makes sense, as it seems the only way power is getting to the headlight motors through the turn signal is through the actual bulb, so it is pulling extra current; much more than the filament is meant to handle. But if it starts acting up again, if you could, to eliminate other possibilities, remove the left turn signal bulb and see if it happens still, possibly drive around like that for a bit to see if it comes back.
The panel under the HVAC controls where the button is supposed to be is completely missing when I bought the car so I dont know if this car had TCS or...
If swapping in an LS motor (lets ignore the rest of the complexity of the swap), what would be...
